Codec and Vista ?
27 Jan 2005
Letchworth Herts uk
Hi All I have a problem deciding which Codec program to use with Vista 32x ? i,ve heard that K Lite pack doesn,t work properly,or is this wrong ? which one is good ? thanks :confused:
Just use VLC, that way you don't have to worry about any of the codecs :)
Hi there just took a look at this ,and must say i,m impressed with the software,looks like a no frills program ,which does what it says on the tin ,which is cool ;)
