Codec pack equivalent to VCP for XP
2 May 2004
Hi,
I'm currently using VCP (http://shark007.net/) on Vista with the x64 components, never had a problem and would like to install a similar codec pack on my XP PC that also uses ffdshow (the main core of VCP is ffdshow IIRC).
Is ffdshow tryouts any good?
Thanks.
You can download ffdshow itself, or use CCP (Community Codec Pack) which basically uses ffdshow with some extras for what ffdshow doesn't cover. K-Lite Mega Codec Pack basically does the same thing as well.
