Codec pack with no rubbish
27 Oct 2005
Netherlands
Hello,
I am looking for an audio and video codec pack with as many encoders and decoders as possible, but without any other rubbish like ffdshow or config crap. I just want to be able to work with all my video's in virtualdub and recode em...
I use Spotify and VLC to play anything so I really just need it for decoding and encoding purposes, I just dislike many packs for coming with so much rubbish.
What is a good pack with nearly all known codecs in but without all the rubbish included ? Need both audio and video codecs... Want to be able to recode h264 .mp4's with 5.1 audio and seperate subs and hardcode subs into it and into a .mkv with stereo audio for example...
Just get the individual codecs.
They often come with lots of crappy apps and consoles too. I just want to encoders and decoders for use in vdub...
Doesn't codes like the klite pack have the option for which codecs you actually need and not install the ones you dont?
I'll try, I just don't want any things like ffdshow, ac3 filter, media player classic, etc...
Codec package with no garbage = VLC
Yes, great isn't it ? VLC's decoders aren't usable in virtualdub though and I don't think it has encoders...
For VirtualDub all I use is ffdshow and LameMP3. Just make sure you get the same versions of VirtualDub and ffdshow (I use 32bit versions of both).
CCCP, or the manual route...
CoreAVC
Matrakosa splitter
AC3 filter
FFDshow (x264 encoding disabled)
Those 4 should take care of the majority.
