- 30 Jan 2014
ive noticed a few of these threads appear so i thought i would join in the fun also i think it will be kewl to look back on and see how i got on building the system. Please remember this is a slow work in progress and will take hopefully between 6-8 from today until completion. anyways i shall start with a list of components.
coolermaster HAF X full tower case
intel i5 4670k cpu
Gigabyte Z87X-OC motherboard
Avexir Core Orange Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz
2 X Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5
HDD unsure but an SSD and 2 X 1tb hdd
1 X laing ddc 18w pump
1 X phobya 150mm gold reservoir
1 X EK 360mm PE rad
1 X EK 240mm PE rad
1 X EK csq supremacy cpu block
2 X EK Water Blocks EK-FC7970/R9 280X CSQ
2 X EK Water Blocks EK-FC7970/R9 280X Backplate, CSQ
Monsoon 19/13mm gold fittings, straight, 45 and 90 deg fittings
black 19/13 xspc fittings
5 X Arctic F12 PRO FANS
5 X Corsair sp120 fans
im sure there are bits and pieces ive missed out but will edit and add in later on.
case arrived today with some rads etc so 1st task is modding the front bay area to house the 240mm rad which im in the process of doing just awaiting friend to come down with a drill and small grinder. will take pics as im working and post them soon
intel i5 4670k cpu
1 X EK 360mm PE rad
1 X EK 240mm PE rad
