COH Bug?
7 Dec 2006
Don't know if anybody who's played COH single player campaign can answer this question.
I think I've got a bug on the final mission - Chambois- it's the one where you have to link up with the Canadians and then defeat the Axis counterattack.
I linked up no problem then the counterattack started.
I've destroyed the counterattack (no more green circles on the map indicating tanks from the counterattack) but the mission doesn't finish, I don't het the mission copmlete screen, I'm just left there with nothing to do.
Is there something I'm missing?
Have you taken all of the unassigned victory points? At some point theres a trigger which sets off 1 last mad armoured thrust from the German side, which can be tricky to counter.
Might be a VP near the Canadian base you need to capture to trigger this? Worth a look.... if not, you might have to re-do the mission.
There are no VP's on this mission, there's a secondary objective of controlling all 4 bridges, but it;s not necessary in order to complete the mission.
I had a simlair problem 4 missions into the American campgain. Destroyed the Axis HQ but the mission didn't end. So I called in motor bombardments everywhere in the general area and won.
