CoH: Fatal Scar Error
25 Jul 2006
Hi, does anyone know a way to get passed this error? Never seen it before when playing this game, suddenly popped up for no reason, as far as I know.
I'm right at the end of the mission now and everyone is dead, and I just need to destroy the V2 rocket. Don't really want to go through the whole level again.
Patched upto 1.4.0.10426, not sure if the later patches will help because I was told they just change the MP.
Is there any command to force it passed this?
Edit: Found a horrible way round it. And to keep opening and closing the menu and then the game would carry on for half a second. Had to keep doing that until the explosives had been planted. :(
You can (I think) open the console which gives more information. CTRL+SHIFT+~ ?
It worked in DoW, I used it to correct a problem I had.
