CoH Ports
2 Mar 2006
The Wirral
Hi Im trying to play Company of heroes online but i cant seem to connect to my friends game.
the ports i have unlocked so far are
UDP:6112
UDP:30260
UDP:9100
ive made sure windows firewall is set to have CoH as an exception and i still cant connect :( any1 having similar issues?Are there any more ports that need unlocking?
PLz Help :)
Your probably both having NAT problems. Use hamachi if you want to play a comp stomp, will get around it.
I had the same issue with Dawn of War (which uses same ports).
http://66.134.89.225/~sic/nettest.html
Run that test (little java applet). Make sure the game is closed tho, otherwise it hogs the ports ;) If both of you have NAT detected, chances are you cant play together (unless you use hamachi).
