COH possible graphical problem
27 Dec 2003
UK PLC
Just got this and have loaded it up and fully patched it.
Set all the graphical settings to max (7800GTX @520/1.37, 2xAA/4xAF).
I started a scirmish game just to have a look at the game and noticed certain areas of the map are whited out, it looks almost like a fog of war effect but doesnt go away iff i move troops close, its on the roofs and some windows of houses and bushes, is this correct as ive only just had a quick look during my lunch break and im now back at work.
Cheers
I have the same card and using drivers 84.xx something and have 0 problems...
I dont have a hefty OC on my card tho.
Im using 91.xx and am fine on all other games at 1600x1200 (Q4,COD2,FEAR), The problem is that these possible graphical glitches look like they should be there in a funny way but it sort of spoils the look of the game and i havnt seen a single screen shot with them on. Once im back home i'l try and capture a screen and post it.
I have the same issue, I think (for me) it only occurs if I set any of the Effects to ULTRA or shadows on HIGH.
If I leave the effects\fidelity on HIGH and shadows on MEDIUM it doesn't occur!
V.Strange!!! :confused:
EDIT: It appears on like tank traps, guns, helmets, roofs, etc. :confused:
EDIT 2: Just noticed you have the same card as me as well!
Hmm I wonder why it does it then.... also did it in the Demo for me and now the full version? I'm also running 91.47. Maybe re-install them as perhaps a file is corrupt. Might do DirectX as well... just incase. :)
