Coil whine?
18 Jan 2015
I noticed recently that my sapphire radeon r9 290 tri-x has coil whine even when it's not under load or playing any games...
Should I contact the company and see if I can get a RMA?
When I play game it get's quite audible.
Not under load or stress, FPS is capped too so it's not running at high FPS.. so, I dunno.
Edit: even when I don't play games, I hear the sound from my GPU.
Is there any way to fully confirm it's from the GPU? What can I do to turn the GPU off to check?
Although I'm quite sure it's from the GPU.
Refunding it and got a new GPU.
A 290x vapor and it even does more coil whining.... when I'm not even doing anything I hear some audible coil whining...
wtf, am I supposed to do. Refund this as soon as I brought it..?
Are there any reliable GPU that doesn't make such audible coil whining..
Ugh..
Only Reliable GPU i personally know of is...
Asus R9 290X DIRECT CU II, worked on an XFX 550W Pro PSU.
Not a sound out of it, except when in heavy use. Then only Fan noise.
*coil whine seems to be a relatively new phenomenon, it maybe due to globalization, thinning out quality materials due to the demands of mass production.
I'm aware coil whining is a common thing nowdays... but this 290x vapor has the most obnoxious coil whining even when not under any load whatsoever..
I have no clue what GPU to get at this point..
Mind if i ask the exact brand & power rating of your PSU ?
*am surprised at a Sapphire card giving you problems, the one's i've had all worked really well.
Hotdog, that should be more than enough.
Send it back detailing your problems and your entire system.
If/When you do get a refund, start a thread asking for opinions on what is the best card to get for your cash.
