Caporegime
- 13 May 2003
- Warwickshire
Hi all
Further to my leaking soil pipe thread, I've decided to rip the garage ceiling out and do a proper job of insulating / sealing it.
We have a master bedroom over a double garage and it's significantly colder than the rest of the house.
The garage has a sectional garage door with what looks like good seals and it closes pretty securely, however three of the four walls are exposed.
There's currently ~15cm of that yellow wool stuff between the plaster board and the bedroom floor.
My question is - what's the absolute Rolls Royce of gold-plated solutions here for a warm and comfy master bedroom?
My current plan is:
- Rip out all existing plaster board and insulation
- Seal holes around pipes etc. with expanding foam
- Fit Rockwool between joists right up to ceiling / bedroom floor
- Fit 50mm Kingspan between joists so that they're flush with the bottom of the joists
- Aluminium tape where Kingspan meets joists
- Board with a single layer of fireboard
- Intumescent mastic between fireboard and garage wall
- Tape, skim, and decorate
- Replace current radiator with the largest that will fit
- New carpet with thick underlay (we are replacing the carpet anyway)
Apart from a warm bedroom, I'm concerned about obeying regs and avoiding any condensation issues with incorrect placement of insulation.
Does the above sound OK?
My current plan is:
