Cold boot / gfx problems with new build. [i3-3220 - GA-Z77N]
9 Jun 2009
London
Description of problems
  1. With 8GB(2 DIMM) of RAM installed 90% of the time it will not boot and go into a cold boot loop which has to be hard reset. Sometimes happens with 4GB(1 DIMM) installed, 10%.
  2. Graphical problems, sometimes not recognizing on my ubuntu install, rarely get glitching.
Troubleshooting completed
  1. Memtest 2 passes on each DIMM in both socket, 2 passes with full 8GB 2 DIMM.
  2. Using only 1 DIMM, workes most of time but does not solve underlying problem.
  3. Double checked all power, 24pin + 4 pin, tried alternative 4 pin.
  4. Reset CMOS via header and by removing battery.
  5. Upped memory voltage to 1.55 from 1.5 default, did seem to boot more frequently with 2 DIMM. Also checked timings, they are as advertised.
  6. Built on outside of case on cardboard box on removable motherboard tray, with barebones.
  7. Reset everything, inc CPU + Cooler and CMOS.
  8. PSU, got hold of a spare PSU off brother, exactly the same, did boot with 1 DIMM and failed once as well, failed completely with the 2 DIMM.
Troubleshooting not yet / can't complete
  • CPU, I don't know anyone else with a 1155 board.
  • MOBO, Same as CPU
List of components from OcUK:
Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W)
Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard I know, Z77 is to support future upgrades
Samsung 128GB SSD 830 Series SATA 6Gb/s Solid State Drive - (MZ-7PC128B/WW)
Lian Li PC-Q03B Mini-ITX Cube Case
Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K)
Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM
At my wits' end
I have no idea what to do guys, I have never had to RMA components before and I really want to be certain of the thing that I do RMA, especially since it is a bit intermittent.
I suspect it is the motherboard, but I really don't know.
I have never had anything like this before, it is so frustrating as normally my troubleshooting steps would work.
Any help will be greatly appreciated, if you need pictures just shout.
Update / Bump
Got a spare PSU off my brother, still getting the same issues, so now I am down to two options, either the motherboard or CPU is faulty.
So any ideas I can try, will contact OCuK now, but want really to cover all my bases.
