Cold Boot Issues
30 Jan 2011
UK
Hi 8pack
I have my chip overclocked to 4.4Ghz with the below settings and on every cold boot I get BSOD no matter how i adjust the settings. I hope you can give me some advise.
Ai Overclock Tuner: XMP
XMP 1600 9-9-9-24-2
BLCK 100
CPU Strap Auto
CPU Core ratio 44
CPU Vcore :Offset Mode
CPU Vcore Offset voltage :0.020
CPU VCSSA :1.110
DRAM Voltage : 1.500
CPU PLL Voltage : Auto
VTT CPU : 1.10v
CPU Load-Line Calibration : High
CPU Current Capability : 130%
VCCSA Load-Line Calibration : Regular
VCCSA Current Capability : 120%
CPU Power Phase control : Optimized
DRAM-AB Current Capability : 120%
DRAM-AB Power Phase Control : Optimized
DRAM-CD Current Capability 120%
DRAM-CD Power Phase control : Optimized
EIST : Enabled
Turbo Mode : Enabled
CPU C States Auto
Thanks.
On an old board I used to have with an i5, this on Auto or Enabled used to cause Cold Boot issues as such it was disabled. Worth a try?
Other options could be raising volts slightly, more especially the ram?
Hi,
Thanks for the responses.
Sorry I didn't mention before am using 4930K along with Sabertooth mobo.
I will up the RAM voltage and test again. I will also try CPU PLL Voltage disabled.
Thanks again i will report back once i tested again.
Just an update so i have gone back to stock as no settings i try makes my cold boot issues go away. No sure if i should try a different MOBO to see what If it will affect the cold boot issues
