Hi,
System specs
Intel Core i5-4690K
Gigabyte G1.Sniper Z97 Intel Z97 motherboard
Corsair Hydro H100i cooler
Crucial MX100 256GB
TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit
HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card from my old PC
Corsair RM850 PSU
Since building this new system I've had problems booting from cold where the system will boot loop. When it does this the system does not post, it just turns on, all the fans spin up then after about 10 seconds it powers down again.
After leaving it boot looping for about 5 mins eventually it will boot into windows. The motherboard debug LED displays code 15, which means Pre-memory North-Bridge initialization is started.
I decided to play around and found that the system boots up fine when the graphics card is not in the system and using the on-board graphics. The system also boots up fine when the graphics card is in the bottom x8 pci-e slot.
Though this is no good as I want to get another 7950 to run them in cross-fire if possible.
I also tried using an old power colour 4780 card in the x16 pci-e slot, in this case the system booted up fine. So seems to be a problem between the 7950 and the motherboard? Maybe only when its using the pci-e 3.0 x16 as the 4780 is only pci-e 2.0.
I've also tried reseating the cpu and checking for bent pins, they all looked ok.
Anyone got any ideas what is causing this and how to fix it?
Thanks.
			System specs
Intel Core i5-4690K
Crucial MX100 256GB
Corsair RM850 PSU
Thanks.
