The title sounds strange, and that's why I'm asking on here ![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
I'm looking at an i3 laptop (approx 3 year's old I think), which appears to be overheating. It has typical symptoms such as screaming fans, blue screens and then it refuses to do anything other than display the power LED (blank screen etc.). I can't monitor temperatures etc. as I only managed to login once for a brief moment. The login screen gets the fan spinning, and a login takes the fans to max.
My understanding is that is has always been noisy (from new) but has recently had the problem where 'the screen won't come on'. A computer shop tried fixing it once, but it didn't help. The laptop belongs to a family member, which is why I don't know the full history.
I've looked inside and it's almost spotless (no dust), and the thermal compound looked pretty good. When it crashed recently, the heatsink/heatpipe near the CPU was only around 35C, and where the fan is, it was less than 25C as the heat hadn't even got that far.
I'm thinking that there is either an issue with the thermal compound or the CPU is running really hot . I was going to replace the thermal compound but my compound appears to be too old, so I would need to order some more, but I don't know whether it's worth spending money on it. The CPU is only 15W TDP, so I'm really curious about this. Any ideas what could be causing this or how to fix it? I've seen some videos online, which show that the heatsink needs replacing, but as the temperature is so low, I wouldn't expect this to be the problem.
