Our 16 year old upvc door won't lock properly. I push the handle upwards to engage the locks but the key won't turn so I have to give the handle an extra boost upwards to be able to turn the key.
I've managed to take the metal strip off the door and oiled the gearbox and lock but it still sticks. It's a 35mm depth gearbox and 232mm high and i've had a look on amazon and found one that looks the same.
Would it be the gearbox causing this do you think? (the part the handle engages with)
