Collecting BSOD
30 Aug 2006
Is there any way to capture what a BSOD says?
For the first time in all my years of gaming im getting one quite regularly when exiting the game Darkensang.
I was wondering if the info on a BSOD is held anywhere and can they be deciphered at all?
You cannot really "deceipher" them.
Many of the stop codes can be Googled and will give you an indicator of the fault, the best BSODs reference a system file which usually indicates a driver problem.
Good old nv4disp.dll for example!
Best way is to set your PC to not reboot on a crash so you can just note down the BSOD there and then.
Great, thanks.
