- 15 Jul 2012
Im in the process of planning my first build i have all the hardware i will be using planned and finalized.
Now im onto the cabling. Could anyone please tell me or help me to figure out all of the cables i am going to need.
I will be using white braided cables for everything possible to keep the theme of white and black.
So far i've figured i am going to need:
YOUR BASKET
1 x NZXT 24-Pin ATX White Sleeved 25cm Extension Cable - CB-24P (BWW) £10.99
1 x NZXT 4 SATA 90 degree data to 4 SATA data cable - White £8.99
2 x NZXT 6 Pin PCI-E White Sleeved 25cm Extension Cable - CB-6V (BWW) £7.99 (£15.98)
1 x NZXT 8-Pin (EPS12V) White Sleeved 25cm Extension Cable - CB-8P (BWW) £5.99
1 x NZXT Molex to 3x SATA White Sleeved 20cm Extension Cable - CBW-43SATA (BWW) £5.99
1 x NZXT Front Panel connections cable set 30cm sleeved - White £5.99
3 x NZXT 3 Pin Fan Black Sleeved 30cm Extension Cable White (CB-3F) £3.98 (£11.94)
Total : £70.87 (includes shipping : £4.16).
Might have to go with a 2 and a 1 depending how far away my optical is from the ssd and hdd. Read somewhere on here to mount the optical in the bottom bay for increased air flow? That right?
I dont think there is anything else i would need the gfx card im putting in is the evga gtx670 ftw edition which takes 2 6pin PCI E connectors
3 sata power connectors 1 for each optical ssd and hdd.
Any suggestions?
Thanks
Fl3tch3r90
YOUR BASKET
Any suggestions?
Thanks
Fl3tch3r90
