- 25 Nov 2009
getting my college project underway now, decided im going to play around with the relationship between case pressures and temperatures.
ive spoken to a few companies that make fans and one or two have them have been really helpful
got 3 freebies off noctua and 3 xilence redwings too
there should be some nexus fans on the way some time next week aswell.
basically what i intend to do is keep prime 95 running at all times and take temp readings off all of the probes firstly with just the fan on the cpu cooler and the two antec case fans on the medium speed exhausting air.
next i will add 1 then 2 (inlet) fans to the front of the case and then a third on the side (over the gpu) gradually increasing the case pressure from sub 1 bar to just over and log the results.
i will also try all (5) fans exhausting air then reverse them and see what happens too.
anybody got any other suggestions to help improve this project?
any help much appreciated
