Colour becoming washed out on B8 OLED after enabling 120hz
10 Apr 2008
I’m trying to play Xbox at 120@1080 on my B8 LG OLED but when I switch over from 60@4k HDR seems to turn off despite being enabled, and the colours become really washed out.
Does anyone know if this is a limitation of the TV or a configuration issue?
Does the tv show hdr coming on?
Wierd, the bandwidth of 4k at 60 is loads more than 1080 at 120. Does your screen support 120hz? Sometimes the B series get a bit shortchanged. I've only got a c9 and that works fine (but isn't really much help to your situation). Do you have the bit rate right? Sorry going off memory and I only have a lowly series s.
Think I figured it out: I had enabled Dolby Vision at the same time as changing to 120hz.
Edit: no, still being weird. After disabling Dolby I got HDR, but something didn't feel right with the 120hz, and the 120hz option was missing in my game's settings (I'm trying to play Warzone 2). Then I restarted and got 120hz setting again but again (and it feels smoother), but no HDR, and Dolby still turned off :confused:
Long short but have you tried turning both off at the mains? I know sometimes hdmi can have handshaking issues.
Just tried that. Hasn’t seemed to make a difference.
Also when I’m running at 4K I can see a HDR option in the game’s setting menu, but not when I’m running 120hz.
I would try another cable, a certified 4k cable. I had a load of problems with my PS4 Pro years ago because the cable it came with wasn’t up to the job. It’s worth a go.
New cable didn’t work unfortunately. I can only put it down to the Series S.
