Colour Code your PC Case!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
You can truely customise your chassis colour scheme now with the new BitFenix Shinobi "Core" Edition Chassis. These cases are provided without any standard mesh trims and BitFenix Logos on the front, you now have the choice of colour codes to make your gaming system truely individual.
BitFenix Shinobi "Core" USB3.0 Gaming Windowed Case - Black @ £54.98 inc VAT
Named after some of the most feared assassins of the modern age, Shinobi empowers the digital warrior to silently and efficiently dispatch his opponents. Maximum expansion and compatibility with long graphics cards enables you to equip Shinobi with the tools you need to get the job done. Superior cooling options allow the system to stay cool and collected during the heat of battle, while a sophisticated yet understated styling shows the opposition you mean business.
Killer Looks
Shinobi carries through the signature BitFenix design philosophy of clean lines, understated elegance, and modern styling. If looks could kill, a glance at Shinobi could be your last.
Choose your destiny
The stealthy digital warrior must adapt to their environment. Available in with or without a windowed side panel, you can choose the Shinobi that blends perfectly with your surroundings. Whether you choose to walk the path of light or darkness, Shinobi has you covered.
Maximum Expansion
Serious rigs require serious hardware. That's why Shinobi is engineered to handle up to three 5.25" drives or eight 3.5" hard disks. You can also install a 2.5" SSD with the included adapter. Best of all, Shinobi can easily accommodate long graphics cards, which means that you can outfit it with the hardware necessary to eliminate the opposition.
Efficient Cooling
The effective gaming rig, like the warrior who wields it, must be cool under fire. Shinobi is adorned with unique mesh areas that can quickly dissipate excess heat. Shinobi can accommodate a bevy of fans - up to seven 120mm or two140mm fans can be installed to ensure that all hardware stays as cool as the blood running through an assassin's veins.
Plenty of connectivity
The efficient warrior must have easy access to all the tools they need to get the job done. Equipped with no less than four USB 2.0 ports, Shinobi offers plenty of connectivity for all your USB devices so that you can keep you gear connected and ready for battle.
DIY Friendly
Fighting should be done in game -- not with your hardware. Shinobi comes with a wealth of DIY-friendly features, ensuring that getting your system setup is quick and efficient. A CPU cooler cutout makes it easy to change out your CPU cooler should the need arise. Shinobi comes with filtered fan intakes, keeping the interior clean and your system looking great. Shinobi Window even comes with convenient tool-free drive locking mechanisms for ultimate convenience.
BitFenix Quality
Shinobi comes with all the amenities and design touches characteristic of BitFenix chassis. BitFenix SofTouch™ Surface Treatment for resistance to fingerprints and stains surrounds the brushed gunmetal BitFenix logo emblazoned on the front. A luxuriously black coated chassis exudes both quality and refinement. With Shinobi, users can experience BitFenix quality both inside and out.
NB; THIS EDITION OF THE SHINOBI IS PROVIDED WITHOUT THE FRONT AND TOP MESH & THE BITFENIX FRONT PANEL LOGO - YOU HAVE THE OPTION TO BUY THE COLOURS YOU REQUIRE FROM OUR CATALOGUE
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 2 x USB2.0 / 2 x USB3.0 & 1 x Audio
Only £54.98 inc VAT.
ORDER NOW
BitFenix Shinobi "Core" USB2.0 Gaming Windowed Case - White @ £49.98 inc VAT
Killer Looks
Choose your destiny
Maximum Expansion
Efficient Cooling
DIY Friendly
BitFenix Quality
Only £49.98 inc VAT.
ORDER NOW
BitFenix Shinobi "Core" USB3.0 Gaming Case - Black @ £46.98 inc VAT
Killer Looks
Choose your destiny
Maximum Expansion
Efficient Cooling
DIY Friendly
BitFenix Quality
Only £46.98 inc VAT.
ORDER NOW
BitFenix Shinobi "Core" USB3.0 Gaming Case - White @ £46.98 inc VAT
Killer Looks
Choose your destiny
Maximum Expansion
Efficient Cooling
DIY Friendly
BitFenix Quality
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Black @ £1.98 inc VAT
Replace the standard BitFenix logo on your current Shinobi or if you are looking to buy a new case you can purchase the Shinobi "core" case which is provide without the BitFenix logo or the mesh strips. Thus allowing you to completely customise your colour scheme for a truely unique looking system.
- Material: Plastic
- Compatibility:
BitFenix Shinobi Midi Tower - Black
BitFenix Shinobi Midi Tower - Black Window
BitFenix Shinobi Core Midi Tower - Black
BitFenix Shinobi Core Midi Tower - Black Window
BitFenix Shinobi Core Midi-Tower - White
BitFenix Shinobi Core Midi-Tower - White Window
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Blue @ £1.98 inc VAT
Replace the standard BitFenix logo on your current Shinobi or if you are looking to buy a new case you can purchase the Shinobi "core" case which is provided without the BitFenix logo or the mesh strips. Thus allowing you to completely customise your colour scheme for a truely unique looking system.
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Deep Blue @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Green @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Gold @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Orange @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Red @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - Silver @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Logo for Shinobi Tower Case - White @ £1.98 inc VAT
- Material: Plastic
- Compatibility:
Only £1.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Black @ £6.98 inc VAT
Replace the standard BitFenix mesh strips on your current Shinobi or if you are looking to buy a new case you can purchase the Shinobi "core" case which is provided without the BitFenix logo or the mesh strips. Thus allowing you to completely customise your colour scheme for a truely unique looking system.
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Blue @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Deep Blue @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Gold @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Green @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Orange @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - Red @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
BitFenix Mesh Stripes for Shinobi Tower Case - White @ £6.98 inc VAT
- Material: Plastic
- Compatibility:
Only £6.98 inc VAT.
ORDER NOW
kul1, any idea if there will be a windowed panel released for the outlaw?
and do you know where i could get a spare drive bay cover also for it?
some very nice stuff for this case here
White mesh strips for me! Although I'm still waiting for these BitFenix Spectre PRO 120mm White LED fans to be in stock....... :p
Questions:
Do the logos fit the XL? I know the mesh won't, but are the logos the same size?
Will you be getting the XL window panels?
Are there plans for XL mesh?
I need some blooo in my life!
I'm really happy to see these! You've come through again BitFenix. I've ordered the white mesh set and the white logo.
What I'd really like to see is some sort of clearish logo for the possibility of backlighting it. Also, although the small meshes can now be changed, the top mesh on my Shinobi is going to have to stay black until I am brave enough to paint it, or until you bring out a white mesh for that too!
