Colour Coding Insides
29 Jun 2005
Newcastle
I've decided to make a new rig, and this time I'd love to do a bit over colour coding so things look pretty tidy, for example Black and red, or black and blue. I've almost certainly chosen my case as the "Lian Li PC-A71FB Full Tower Case " and buy a window for it. I wouldn't mind some help with what people may have with regards to the rest, like lighting, and especially the motherboard and graphics cards.
my advice would be spend a good long time thinking about your colours, maybe even rough sketch and get your self some felt tips ro get an idea. keep it to just w colours and if one of them is black then just one colour for lighting or its going to look like the outside of a dodgy nightclub. i would choose you mobo and then if you really want collars and cuffs to match then pick your paint colour to match
if you're going down the full braiding route check out the colurs first as it' be a shame to get everything else then not be able to get braid that fits with the colur scheme
but as i said at the beginning take your time
Motherboard will usually be the hardest to match up, followed by graphics cards. Though as G-Dubs said above its the small bits that brings it all together (braid etc).
Red and black have been extremely popular since the Classified and Dominator GT RAM came out so going for something different is always good :)
