Colour scheme issue
8 Mar 2011
I hope this is the right forum to post in
I get this issue some times after playing bf3
http://i.imgur.com/cIogu.png
I know its not the biggest issue but maybe its an issue that is leading up to a bigger one, idk?
I play BF3 on the max to ultra settings
computer specs
I5
8gb ram
2x gtx 570s
Im hoping someone knows whats the story is
Locate BF3.EXE, right-click and select the Compatibility tab and place a check in Disable desktop composition and it will switch to the basic scheme as soon as you start the game (and switch back when you close BF3/Origin) so you'll never get it while playing.
But it's a BF3 issue, not your system.
its not a problem click keep the current at the bottom
its just ur pc is trying to save itself work tbh it means u have things enabled that slow down your pc like lovely windows textures and stuff the game dont use so when u go back into windows it thiunk hmmnn do i need that
answer is no but it make windows look slick
there is no problem its just trying to be smart saying hmmmn we can take u back to simple mode and speed u up a bit thats all
it happens with some games its not a prob
Thanks a lot Chris, done that.
thanks
