Coloured Cable Connectors?
22 Aug 2016
Hi
I know that OC do lots of cable kits, and I love the green set that they do. Unfortunately the connectors are black and I am looking to see if I can get them in white instead? I suppose my question is; Is this a job to literally construct all the sleeving / connecting myself if I want this level of customisation, or is there some simple connector "swap-out" or "Spray-paint" method I haven't heard of?
Any advice would be greatly appreciated.
Thanks in advance.
You can buy coloured connectors easily enough, and you could then simply use an ATX/PCI-e pin removal tool to extract the individual sleeved cables from each connector and then re-insert them into a coloured connector of your choice. This is a bit time consuming but doesn't require much skill. No need to go to the effort of sleeving cables from scratch.
