Coloured Fans
24 Sep 2007
Oxford
I've got room in my case for:
FRONT, 1 X 120 mm
REAR, 2 X 120 mm push-pull through H70 rad
SIDE PANEL, 1 X 120mm
TOP, 1 X 80mm Fan
I've got a sharkoon silent eagle in the front, and tbh it is a lot of faff to get it out but I'm quite happy with that. However the others are antec ones which are quite loud and have seen better days (over three years almost constant usage).
I was thinking of a Noctua vortex control to go between the rad and the case and then a pair of enermax vegas fans in red (mus have red leds) for the case side and the internal side of the rad. Are these likely to be any good?
Is it worth installing the 80mm fans on the roof and floor of the case or would I be better served running a 120mm with an adaptor or not running fans at all?
The Vegas are among some of the prettiest fans on the Market. On the whole Enermax fans are decent performers too.
+1 for the Vegas :) they look awesome - and going by the stats they should be really good on the rad
Just had another look at the stats and it's got me tempted to get a pair to sandwich my Ultra120 between :D
