- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Light up your world with this amazing new LED control panel with included stripes.
NZXT HUE RGB LED Controller - Black @ £34.99 inc VAT
NZXT has expanded their bay devices with HUE; an LED configuration that is customizable to your liking. HUE grants you the power to select how you want to illuminate your chassis with infinite possibilities. Take charge of the RGB controls to adjust the color fade, pulsating light effects, and brightness levels of your internal LED sleeve. HUE is equipped with an on/off mode for times you may need to go stealth and possesses a unique semi-mesh design, blending flawlessly into any chassis with a mesh front panel.
- Infinite color options that you can customize to your heart’s content
- Three RGB controls to adjust the color settings, brightness level, and pulse speed of the internal LED sleeve
- On/off mode to completely disable the LEDs
- Effect modes: normal, fading, flashing, and pulsating of colors
- Internal LED sleeves that vibrantly illuminates and accents your chassis based on your liking
- Unique mesh design that blends flawlessly into any chassis with a mesh front panel
- 5.25" ODD
- 3 RGB dials
- 5 Brightness Levels
- Modes: NORMAL, FADING, FLASHING, COLOR FADING, AND COLOR FLASHING
Only £34.99 inc VAT.
ORDER NOW
- 5.25" ODD
- 3 RGB dials
ORDER NOW
