Column 'thetimestamp' in order clause is ambiguous
7 Jan 2007
Sussex, UK
I have a mysql database and I have successfully joined four tables, two of which have the same column titled 'thetimestamp'.
I have written a script to query these and join, then order by thetimestamp but it is erroring with:
how can i tell it that table1.thetimestamp = table2.thetimestamp = table3.thetimstamp etc etc
This is for SQL, but I understand the syntax is similar in most cases. Joins Customers to Orders and then orders by the order timestamp value.
SELECT
c.*, o.*
FROM Customers AS c
INNER JOIN Orders AS o
ON o.CustomerID = c.CustomerID
ORDER BY o.TimeStamp
PHP:
          $query =		("SELECT *
						FROM parentcompany
						JOIN products
						ON parentcompany.idoperators = products.idoperator JOIN company1
						ON products.idProducts = company1.idproducts JOIN company2
						ON products.idProducts = company2.idproducts
						ORDER BY thetimestamp DESC
                        LIMIT 3");
You need to place the table name in the order clause, since you have the same column name in multiple tables.
order by table1.thetimestamp
If the timestamp is the same in all tables it doesn't matter which you choose to order by.
yes the timestamps will be different but that is irrelevant, you can only order by the timestamp field on one of the tables, the rest will just be in whatever order.
You can do like this to order by multiple columns though:
ORDER BY table1.thetimestamp, table2.thetimestamp
It will then order by the table1 timestamp field, then by table2 timestamp.
