Well been working on an application involving asp and COM's which has been working fine. On Friday I was messing around with a print service in .Net and was having problems with it and eventually got it in a state where the service for it was stuck in a 'starting' state.
To fix this I tried a few things like uninstalling .net 1.1 (which it uses) and reinstalling etc. reinstalling MSDTC etc which didn't seem to fix the problem.
Later when I gave up and went back to the ASP / COM web application its no longer working
all i'm getting is an error message with the following.
MyUtility (0x8007000E)
System Error &H80004005 (-2147467259).
/test/again.asp, line 5
Any ideas what i've screwed up ? been going through a few sites and found the odd thing but nothing relating to ASP/COM issues on this. the only ones that do mention this don't finish with a solution
Little update:
It appears that its a problem with coms that try and talk to the database, created a simple one which just returns a string and that worked ok.
Little update:
