Hello, as above I want to add to my HyperX 4GB (2GBx2) PC2-8500 1066mhz KHX8500D2K2/4G (I believe)...2GB (1 stick) of PC2-6400 800mhz HyperX KHX6400D2LLK2/4G!
PC2-8500 can run @ 800mhz (1.8v) and 1066mhz (2.3v) - I believe 5-5-5-15
PC2-6400 needs 1.95V at 800mhz and 4-4-4-2 I believe!
So will it be compatible if I run them together at 5-5-5-15 1.95V @ 844mhz (844mhz as my CPU is OC'd)?
Thank You!
Thank You!
