Hi,
Long time reader, first time poster! Completely lost on something that seems relatively simple...
My electrician installed a Comfast 300MBPS wireless ceiling AP... problem is he installed it above the ceiling, so i cannot get to it!
He had wired cat6 cable back to my virgin router, i plugged it in and it works well, i get great signal and can connect and browse fine. My issue is, it seems to have created its own, unprotected network. Anyone can access this network and it isn't password protected. I have googled and they suggested i typed 192.168.0.1 into the browser to set it up. I have entered that and nothing happens it just times out... I know that a login was possible as i saw the electrician on the comcast landing page. I am worried he has set it up incorrectly and I need to go in to correct it so it boosts my current network rather than create its own unprotected one.
I looked into system preferences to look at the comcast settings and it states its IPv4 Address is 192.168.0.18. I (naively) thought if i entered that into my browser that would allow me to login, but that didn't work either!
Electrician isn't being very helpful and won't come back to look at it (as it isn't his expertise, wish he'd mentioned that when he said he would install the unit!), so i hope someone on here can help! All help appreciated
