** Coming Soon to Overclockers UK: Silverstone Heligon CPU Cooler - Pre Order Discount**
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Coming soon, the brand new high end cooler from Silverstone.
This pairs massive performance with a long overdue design characteristic where the cooler actually allows for installation of memory with tall heatspreaders.
As a special promotion, OcUK are offering special pre-order pricing on this heatsink. When it lands, the pricing will be going back to its regular price point.
you have about one week to take advantage of this offer before our stock lands!
Silverstone Heligon SST-HE01 CPU Cooler Intel Socket (Socket LGA775/1155/1156/1366/2011/AM2/AM3/FM1/FM2) @ £54.99 inc VAT
Designed for ultimate performance without the risk of inteference with tall memory heatspreaders, the Silverstone Heligon Cooler is the paramount tower cooler for high end systems.
The all new Heligon HE01 CPU cooler is designed for both performance and quietness. The wide aluminum fin spacing are specially designed to minimize noise when air travel through its heatsink. The included 140mm fan offer exceptional cooling power, this low noise fan is also adjustable allowing you to decide the right amount of airflow for your CPU. With the include fan clips, up to three 140mm fans can be installed to enable HE01 to obtain cooling performance that rival the best air coolers on the market.
The Heligon HE01 is capable of safely cooling high-end CPUs such as the Intel Core i7 3960X. It has the ability to cool CPUs up to 300W. For those looking to obtain the highest cooling performance at the lowest noise possible, the SilverStone Heligon HE01 is an unbeatable solution.
• Superior silence and performance
• Six soldered heat-pipe, copper base and aluminum fins ensuring the best thermal conducting efficiency.
• Designed for standard chassis at 164mm tall
• Include adjustable 140mm fan for excellent cooling and low noise
• For use with CPUs up to 300W
• Intel Socket LGA775/1155/1156/1366/2011 and AMD Socket AM2/AM3/FM1/FM2 compatible
Was £59.99 Inc. VAT
Only £54.99 inc VAT.
ORDER NOW
"Designed for standard chassis at 164mm tall"
who they trying to fool^^
looks nice tho, shiny anyway! :)
Meh, heatspreaders on RAM adds nothing anyway, might as well get LP stuff. Looks like it could be a decent cooler with atleast 1 extra fan added.
its good enough on its own but comes with handy clips to add more fans should you require it.
Tweaktown have given this a 90%+
that is not bad at all
