Very nice! Do they actually have the gradient like the pictures show or is that just the way they photograph if that makes sense?
Dont like it.
it will throw the aesthetics of the whole build off. you have the water in the res one colour and the water in the tubes a different colour. now that will be thrown off even more if you use lights in your case.
they would have to be RGB to satisfy serious modders
well you wont need to worry because you wont buy one then lol the reason i like it is because it negates the need to flush your system everytime you want a colour change you can change a light colour easier than a liquid colour![]()
you do realise that its only the water in the res that the will be affected by the light in the res? the water in the tube is still going to be the same.
