Command & Conquer 3: Tiberium Wars
Caporegime
20 Oct 2004
Never played a rts on a console before and wondering what there like without K & M. I think it would be pretty weird.
This does look like one of the best C&Cs in while as well and not want to ruin 40notes on a game that is impossible to use.
It will probably use a similar scheme to how LOTR:BFMEII worked - the pointer stays in the middle of the screen and the map moves about it. Selections are made by pressing A and different button/trigger combos. That game was kind of the test. It only sold about 150k copies but it was enough for EA to bring C&C3 to the 360.
Download the demo of BFME2 and check it out, see if you like the control method as I would think C&C would be similar.
I downloaded the BFME demo yesterday, and I really liked the control system, I thought it was quite inovative.. personally I cant wait for C&C3, im a die hard fan of all of them, and this one looks especially good, and I think it will rule as for one, it will be the first C&C game in full high deffinition, and will just look marvelous..
thanks, going to download the demo right now! Hope it is good, although may just stick with the pc version for this game.
But my pc is quite lacking in power and not wanting to spend a crap load upgrading. Well see how the demo goes anyway.
But the game looks awsome, been wanting a decent C&C since RA2..... goes away to find RA2 disc.
From what EA said, the specs should be very similar to BFME II
Just so you know ;)
Owell looks like PC should handle it fairly fine then, doesn't look gfx hungry. Still on agp, 6600gt.
although im getting it on PC, BFME2 on console will have pretty much the exact control scheme, and i have that and it really does work nicely, although not AS good as K+M, its still not bad if you dont have a PC capable of running it.
i am so looking forward to this game, i remember playing the others as a kid, can't wait to play this new one! Always a fan of NOD, always better being bad and of course mammouth tanks!
Seriously cannot wait for this.. im counting down to the 11th of may (Which is now the confirmed release date for the Xbox version)
