Command Prompt Help needed
12 Feb 2006
Surrey
just realised i posted this in the wrong section so i posted here instead.
im trying to get to a file in 'program files' by using command prompt, but the first place it starts at is 'my documents' which is too far in. anyone got a clue how i get to program files from here? or if there is any other command prompts that start higher up e.g. C drive?
the command prompt i found was by going to start, all accesories, accesories, command prompt, dont know if the helps at all
