Comment on my proposed fan layout :)
28 Aug 2006
I will have;
2x 120mm Fractal fans front sucking IN
2x 120mm Enermax fans rear (H50 push/pull) IN
1x 140mm Fractal fan bottom sucking IN
2x 120mm Fractal fans top exhausting OUT.
My main idea is to have a rising column of air aiding the natures rising heat.
Case Fractal R2.
Comments very welcome.
That really is a lot of fans.
Are you running an i7 at 4.4ghz on air or something?
Nope, just an OC q6600, Ati 5870 and about 5 H/Ds
I was just thinking about having a moving airflow environment. All the Fractal fans are less than 15db to reduce noise.
