Hi, thanks for reading.
Have I overlooked anything with the following setup? Would like a good gaming rig, and can spend more if necessary, but would prefer not to if its just vastly diminishing returns. I plan to do some moderate overclocking of the cpu to 3ghz. Will probably not try on the gfx card as I've never managed a stable aircooled overclock on one that doesn't glitch in some games.
2x GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (£234.98)
1x Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (£191.51)
1x EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard (£176.24)
1x BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (£387.74)
2x Samsung SpinPoint T HD501LJ 500GB SATA-II 16MB Cache - OEM (£176.22)
1x Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM (£22.31)
1x Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) (£99.86)
- Will the corsair be able to power another GTX card as well when I go to SLI in the future?
- Whats the score with sound cards these days? I'm installing vista and I don't think anything from creative works. Is the onboard sound ok?
- Is this mobo a bad idea? I know it has some controversy around it, but I want the dual sli bandwidth for a second GTX in the future. If it is a bad idea, any other suggestions? I've seen the P5N32E Plus which is a hybrid chipset. People seem down on this, but doesn't it work around some of the fragility of the 680?
Haven't chosen a case yet. Any recommendations? Must be quiet so I don't want mesh side panels hiding fans if they let noise out. Would like it to be ally and nice looking too.
Thanks.
Thanks.
