Comment on this spec please..
28 Jan 2005
A friend needs a bit of an upgrade as his system's just died. Looks like the motherboard, but we can't establish if the CPU and PSU have gone too, so he needs most of it replaced.....
Only going for cpu/board/graphics and PSU as everything else will be carried forward.
Any comments on:
BFG GeForce 7600 GT OC 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
OCZ ModStream 450w ATX2.2 Power Supply
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB)
[edit] It won't be overclocked![/edit]
His budget is £400, and I've picked this lot as it comes to £411.13 inc vat+delivery.
Anything you'd change?
Ta.
yea, same as said above, that price range, you have done a brilliant choice on parts, would go ahead with that :)
ags
Cheers.
I was a little concerned as I read the OCZ PSU is slightly larger than normal, but if people think that's ok for a standard ATX case then I'll recommend that setup to him :)
Good PSU for the price that. I notice it has some good reviews. Has some good rails and it also looks pretty funky too!
All the best on the build, he will definately be happy!
