Comments Please
16 Jan 2008
Care to give some comments on this design? Looking for clean easy navigation!
TIA
What are you asking, it is just a simple rollover menu bar a search box and a man content area, it is very basic but i don't see why not. You will find many web designers pages are very basic.
Well it looks idiot proof to navigate as you have 1 bar with 5 pieces of text that look like links as one of them is highlighted.
The search box looks minimal but how do you submit a search? I know most people would press return/enter but you need a button there to not make users think about what they have to do.
If you're looking at making something that is straight forward, not making the user think, then read this book, it will help a good amount :)
Don't Make Me Think! A Common Sense Approach to Web Usability by Steve Krug
Good jumping off point but agree with Trip above. I think you could reduce the header drop shadow a bit as well but that's maybe just personal preference. :)
The spacing between the top nav, main contents, and right featues doesnt seem to match.
Looks pritty clean, apart from the spacing issues :p
The top banner, doesnt match up with the width of the middle, or footer either. I would prob just change the footer width tho.
