Caporegime
- 8 Jul 2003
- In a house
Hi all,
Anyone had trouble updaing Comodo Firewall, i checked for updates the other night, said there was some, and would i like to install em, so i said yes, but then it goes major slow, must be slower than dial up speeds, after about 40 minutes it had only done about 73%, then not long after it came up with a 108 error (summit to do with not being able to update/find updates or something can't remember), but everytime i try to upade it it just will not do it, goes major slow while downloading the updates, then just stops with errors after a while, ive been on about 2x days now trying to update it but it wont have it, im even getting the flashing yellow down arrow now on startup saying theres some updates do you want to install them, but it just does the same with that, downloads at a crawl then just stops when its done so much with an error, so everytime i startup now i have to keep saying no i don't want the updates as i can't get them, can this thing be updated or what!!!!.
Thanks.
Thanks.
