Comp advice for a foreign friend
Permabanned
28 Dec 2007
I have a friend in Denmark who wants advice on premade PCs. She has very little PC knowledge so building one herself is out of the question, and she lives in Denmark so I can't make her one myself.
I think it's OK to link to this as it's a Danish shop (if not I'll delete):
http://fcomputer.dk/?show=lists_systems_view&list_id=10
She's looking at the top two comps there. Are they decent value for money? I'm not up on current hardware so I don't know. 4,295kr is about £517. What could you get for that price over here?
Cheers.
Spec:
Intel Dual Core E5200 2.50GHz 2MB S-775
ASUS P5KPL-AM/SE Intel G31 S-775
2GB DDR2 PC6400 800MHz 1.Part
512MB Inno3D GeF 9800GT DDR3 PCI-E
250GB Maxtor 7200rpm SATA2
NZXT Apollo Steel Sort u/PSU
650W Energon EPS-650 120mm
Standard Intel Køler
48x16x Lite-On DVD Sort PATA
That's pretty nasty for 520 quid. A very quick look at ocuk puts an equivalent/marginally better machine at 400, and I thought the euro to sterling rate sucked. Does she want to play games on it?
Spec:
yes but what you are looking at is parts to build the machine your self you have to llok at pre-made ones over here to get a comparison
