Comp died
21 Jul 2007
Tonight my comp just died. Everything running tip top then just stopped. (initially thought i had been kicked from a CoD2 server for owning)lol jk.
I notice when i try to power up my psu fan is not running could this be the issue. My internal fans seem ok just the psu 1 seems to not work. I have a 550w supply running a q6600 and 2 7900gtx in sli, psu over 18 month old.
I see a name on the side says advance. Only name i can see. Been running SLI on this psu for 18 months or so but its just froze tonight.
he has 7900gtx's.
the psu fan not running is not good as it means the psu will overheat if it hasnt all ready. when it went wrong did the screen of off or just pc froze ?
he has 7900gtx's.
Not sure which it did. Screen went blank and pc still looked as though it was powered up. I turned the power off at back of comp and now it dont power up.
Sounds like a pretty nasty PSU, was probably always going to be questionable with SLI!
Don't try and power it up again... grab something like a Corsair HX520 and hope your mobo isn't fried.
