Comp issues
Permabanned
5 Aug 2008
In my bedroom
Got a custom build consisting of
MA78GM
Corsair DDr2 6400
AM2 4800+
Now and them when I run a hd dvd I notice -
Core temp getting to 70's
mem usage constantly on 100%ish
Now and then the comp would just cut of and shut down instantly.
What is the cause of this? Ram ? Heat?
Sounds a bit like heat. What cooler do you have on the X2 4800+?
On the memory usage, hmm, how much do you have?
Could also be bugged drivers I suppose but the CPU temp still seems toasty to me.
I didn't think that playback on 780G used that much of the CPU, am I wrong?
The CPU temp is not one I would be comfortable with but is it responsible for your problem? I'm not sure. The memory usage spike is odd.
Could a wire be impeding the CPU fan? BIOS problem? Memory that isn't seated properly?
Ok I am now certain it has something to do with me running hd dvds.
As soon as I started watching a hd dvd, the usage goes up to 90% and the core temperature goes right up. Then it literally cuts of.
When I was watching a normal dvd temp and usage remained low.
I assume now its down to either mem usage or heat.
I would try fresh windows install ;). Looks to me like messed up system seriously.
Does it happen when playing games ? and what are your idle temps like ? can u check with orthos if it does the same ?
The xp is pretty much fresh, it has been on for about 2 weeks.
This is about 8 mins afer my computer cut off ...
I will run orthos tommorow.
