- 7 Dec 2019
I'm looking for the case that can fix at least 2x 240mm (60 mm thick) radiators.
I already own a bunch (three or four are laying around) of these radiators and would like to build a custom loop of it.
Currently, my system is squeezed into MetallicGear Neo Mini (V1), but I was able to fit only one of these radiators (in front of the case).
Preferably I'm looking to put the radiator at the bottom of the case, but it's hard to find the case without the bottom chamber for the PSU.
Although my motherboard is the Mini-ITX size and the graphic card is short (Nano Vega 56) the case mustn't be an ITX format.
I was considering:
* Lian-Li O11, but it's a little bit too big for me;
* Antec P120 Crytal which is similar to Lian-Li but narrower (also there are cheaper counterparts in form of InWin 101/130);
* Phanteks Enthoo Evolv ATX seems good for the purpose, but it's also big;
* Fractal Meshify C - seem to be able to fit the radiators at the top and the front;
All those seem to be fine, but maybe you could recommend something more compact?...
I was considering:
