Compact Flash or xD?
18 Jan 2006
Newport
Sorry if this has been covered before, but the minimum word length makes searching for xD a pain! ;)
I've a got a new camera coming for Christmas which takes both CF and xD. I already know that CF is cheaper, while xD is a smaller format.
Aside from those points is there anything else to consider? Which would you guys choose and is it a case of just getting CF because you can get more for you money?
I'm forced to use xD and I hate it. Slow read/write speeds, slow transfer speeds when I want to move the pictures to my pc, and I keep loosing the damn things.
Go with CF.
i use both in my e500, simply because i had a 2gig d card spare and it came with a 4gig cf card, the xd is a little slower which can be a pain but you soon get used to it.
Go with CF. If you end up with a mid/high end DSLR, its highly likely to be CF. Im having to buy CF cards now that im going to be getting a D300.
