Compact Flash
ajm
ajm
13 Apr 2004
What is the difference between CFI & CFII? Are they the same size and just different speeds? I am wanting to buy a pda which has CFII but the card i have been looking at only seems to come in CFI.Will it fit and work ok in a CFII slot?
CFII slots are backwards compatible with CFI. I'd get a CFII card if possible because the speed increase is noticeable.
Just out of interest, what PDA are you looking at getting?
Thanks for the quick reply.I am looking at the Dell Axim X51v 624MHz Pocket PC but not quite decided yet.It has CFII but the sirf antenna i have been looking at is only CFI.
Me too but finding it hard to find a similar spec at that price range or even slightly lower spec at that price.
