Compact mini itx and SFX case needed
16 Jul 2004
Home
Hey all,
I have an old mini itx motherboard and SFX power supply that I wanted to cram into a small space and run headless for storage of key documents.
Can anyone suggest a cheap basic case? Second hand ones seem hard to come by.
I don't need to add gfx card and will put in an SSD.
Thanks!!
Looks good to me, I would have suggested DAN case but that would be a waste unless it is used for a high end system.
Gosh that silverstone case is only 10cm wide, doubt you'd find much smaller. They are normally good quality too.
Thoughts on the Silverstone ml06-E?
Its seems unless I go for a Pico PSU, then this is the smallest I've found...
That looks internally identical to the ML09 I've just built. I have a thread in Project Logs describing how it all went together but I'd say go for it as long as it's a reasonably low-powered CPU and a low-profile HSF.
