So I have a build planned and the case is already mocked up etc. But the project is essentially to squeeze the most performance into the smallest cube possible and I want to watercool it, just for the heck of it, and because air is going to be noisy as hell in this enclosure.
So the setup is going to be something along these lines, the thickest 140mm radiator I can find with push-pull fans, say around 100ml res, and a pump like an EK DCP 4.0
Really what I'm trying to ascertain is what's the maximum TDP a loop like this could handle, it needs to cool the CPU and the GPU, and the performance doesn't need to be stellar, I will settle for 80c+ on CPU and GPU at load.
So any feedback would be appreciated so I can try and spec the hardware accordingly to what this sort of setup could cope with without exceeding the maximum operating temps of the hardware involved.
Thank you!
Thank you!
