company of heroes, using second monitor?
21 Jul 2005
hi all, quick question
i have a dual monitor set up with a standard 19" and a widescreen 20", i was wondering it i could configure company of heroes to play on the second monitor (the widescreen one) cuz it defaults to the first screen, it is easily done in tomb raider anniversary through the config app but i cant figure out how to do it with COH
any ideas?
If you set your widescreen monitor as primary in windows display properties then the game will start in that screen.
yeah i tried that and it does work its just all the dialog boxs open on that screen now, which isnt what i want, theres noway to configure it only in the game options?
In that case try Ultramon - you can use that to configure which monitor programs open on - although it can be a little hit and miss with monitors.
