Comparing £2k Machines
4 Jun 2017
Hi all,
I am looking to get a new PC at around the £2k mark.
I have found this on OCUK
https://www.overclockers.co.uk/tita...i5-7600k-4.8ghz-kabylake-fs-125-og.html#t=b1d!
and this on (where we buy most of our work kit)
** No Competitors **
What would be the benefits of the OCUK one? It looks like the RAM is a little better?
Alternatively what would be a good option for a £2k Gaming PC with a 1080TI and i7 processor? I won't be building it myself.
Cheers!
Jack
I see that link didn't work! Doh!
You can search for the link and it will come up with the website.
Alternatively:
Processor
  • Intel Core i7-7700K 7th generation processor
  • Base frequency 4.2GHz, turbo to 4.5GHz
  • 8MB SmartCache
Memory
  • 16GB Kingston Hyper X Fury DDR4 2400Mhz RAM
  • Supports up to 64GB RAM
  • 4x DIMM sockets (2 used)
Hard Drive
  • 3TB Western Digital 7200rpm HDD
  • 256GB Intel NVMe SSD boot drive
Optical Drive
  • ASUS DVD/RW
Software
  • Windows 10 Home
  • 30 day trial of Microsoft Office included
Motherboard
  • ASUS Strix Z270H
Graphics
  • GeForce GTX 1080Ti 11GB graphics card
  • 2x DisplayPort
  • 2x HDMI
Audio
  • High definition 8 channel audio
Networking
  • ASUS 1300Mbps WiFi
Power Supply
  • 750w PSU
Dimensions
  • Height: 480mm
  • Width: 200mm
  • Depth: 465mm
Motherboard Interfaces
  • 1x DVI
  • 1x HDMI
  • 2x USB 3.1 Type-A (rear)
  • 2x USB 2.0 (rear)
  • 4x USB 3.0 (rear)
  • 1x PS/2 keyboard/mouse combo port
  • 1x LAN (RJ45) port
  • 5x audio jacks
Expansion
  • 2x PCIe 3.0 x16 (1 used)
  • 1x PCIe 3.0 x16 (x2 mode)
  • 3x PCIe 3.0 x1 (1 used)
  • 3x external 5.25" bays (1 used)
  • 8x internal 2.5"/3.5" EZ-Swap bays (1 used)
LEDS
  • RGB LED fans
Case
  • StormForce Lux Gaming Case
  • 2x USB 3.0 (front)
  • 2x USB 2.0 (front)
  • 2x audio jacks (front)
Cheers!
Can't see the other company, but OCUK you get great customer service should anything go wrong. Which if you're buying a pre-build is probably part of the attaction. I've bought hardware from lots of places and so far they are the best i've encountered.
You can find other companies cut corners on parts that people don't look at so much such as the power supply, which can cause issues. They don't mention the brand, which isn't a good sign, may be ok.
"750w PSU"
only gaming? if so i would look at 6 cores 4 cores its will not last much longer if you plan to keep it a long time
Ours has a higher quality case, higher quality PSU, faster memory , higher spec motherboard, a better quality, higher spec cooler and we overclock the CPU for you. Need any more reasons to buy OcUK?
