Comparison help
13 Feb 2011
First post, hello all! :D
Now I'm looking at two sets of DDR3 RAM as I'm looking to replace some faulty ones of mine. Now Ive been looking at two sets, namely:
Corsair XMS3 4GB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS
Corsair Vengeance 8GB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-295-CS&groupid=701&catid=8&subcat=
Now apart from the obvious increase in available memory for the second one, i was also wondering if the slight decrease in latency for the vengeance will show any notable performance increase? Namely to justify the price difference. ;)
Had a read through your links Stulid, you wasn't kidding about the timings much! :D Although it does make a bit of difference so i may consider sticking with the vengeance set. Thanks for the help. :)
