Compatability question
4 Oct 2006
In my old computer I have these 3 pieces of RAM (1 512mb, 2 256mb) and i'm just wondering if they will be compatible with the motherboard I am planning to buy from overclockers
http://www.crucial.com/eu/store/partspecs.Asp?IMODULE=CT6464X335
http://www.crucial.com/eu/store/partspecs.Asp?IMODULE=CT3264X335
Will work with this motherboard.
http://www.asrock.com/product/ConRoeXFire-eSATA2.htm
Edit: woops, did it in a hurry this morning. Is the manufacturers website acceptable for a link?
If the RAM isn't compatible, would it be possible to get some advice on what I can get for £70 maximum which will work?
Firstly, remove the links to competitors website please.
Secondly, both links are for the same thing.
No they won't work in that board. They are laptop DDR RAM and you need desktop DDR2 RAM for that board. How much RAM are you needing?
The Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit here for £88 would be your best bet. Memory prices are unbelievable high at the moment.
Great thanks a lot.
So the finished machine will be:
Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard (MB-003-AK)
Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail (CP-127-IN)
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) (MY-083-CS)
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-025-BG)
Antec NSK4400 Mini Tower Case - 380W SmartPower PSU (CA-052-AN)
This all works together correct? Just to make sure. :)
Yip they're fine.
Bear in mind that if you're planning on overclocking the e6400 you won't get much more than 2.4Ghz from that board.
If you're not overclocking then that combination is grand.
Thanks for the information, just a quick final question.
A couple of my mates say I should beef up the power supply to around 450W or 500W for the graphics card.
Should I go for this or is that current PSU good enough?
